Knock Sensor
Old Oct 12, 2000 | 11:25 PM
Dean Fritz's Avatar
Knock Sensor
I know this is not a prom issue but, I thought I would ask it here. Due to space requirements (Headers) I can not put my knock sensor back in it's original location. Where can I relocate it? Can I put a 90 degree fitting on in it and face the plug connector to the front of the engine? I heard I could put it in the radiator, but I don't think that would work.
Old Oct 12, 2000 | 11:49 PM
Brent's Avatar
You could thread a 90 degree fitting in the block. Since the sensor reads vibration in the block you probably want to use a fitting that is as close to cast iron as possible. Chances are you'll have to experiment with installation torque to get the sensor reading the way it did before. The possible problems I see are over sensitive (false knock) and undersensitive.
Placing the sensor in the radiator will not sense knock.
Old Oct 13, 2000 | 07:59 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
With Long Tube headers you need to do one of two things ... use a 90º fitting as already suggested ... or, simply move the knock sensor the the other side of the block. There is another hole in the other side of the block in the same spot.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 13, 2000 | 02:43 PM
Dean Fritz's Avatar
I am using block hugger headers. I have enough room to put a 90 or even a 45.
Old Oct 14, 2000 | 08:12 PM
FastBroker's Avatar
You can weld a NPT bung of the appropriate side somewhere on one of the motor mounts, if there is room. You can put it anywhere that is physically attached to the block...
Old Oct 14, 2000 | 08:34 PM
Dean Fritz's Avatar
I had been told by a engineer at GM that the knock sensor had to be mounted on the engine block in a water passage. He theory was vibration is picked up better in liquid than in air. Does he sound like he knows what he is talking about. He also said that if a person uses the incorrect amount of
anti - freeze to water that the knock sensor would not work correctly. He said straight anti - freeze would cause the motor to knock because the sensor could not detect it.
Old Oct 15, 2000 | 01:12 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Traxion is right, there is a spot on the other side of the block, same location where you can put the knock sensor
Old Feb 23, 2011 | 08:14 AM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
Re: Knock Sensor
Yeah, this thread is old.... Really old. But, I'm bumping it.
Does anybody else have some different solutions? I'm dealing with block hugger headers that make using the block coolant plugs impossible for the KS. I'm thinking about running a Vortec Motor Knock Sensor, mounted in one of the bolt holes in the back of the head (Like a Vortec motor). However, the engine I'm working on does not have Vortec heads. Anybody see a problem with this?
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
