One BLM cell for entire WOT run?
Old Oct 19, 2000 | 04:09 PM
Yelofvr's Avatar
I just got my 383TPI in my vehicle and did after break in did some WOT runs and recorded the data using my Diacom. Overall the data looks good, o2 800-850mV, no knock retard, etc. My problem is that when I look at the BLM cell number it stays the same from 1000 rpm to 4600 rpm, never changes??? As I understand it, the BLM is a 16 cell matrix based on RPM and engine load. For this reason I would expect to see 4 different cell numbers as my rpms go from idle to redline. Can anyone help? This is my first time using a Diacom. Thanks
Dave Zelinka
Old Oct 19, 2000 | 04:39 PM
BOWTYE8's Avatar
could use more info.
The blm in open loop will reside at 128 actuall both the int and blm. When in closed loop you want the blm to stick in the 120 to 128 rng . it may stray from this under normal drivng. The blm max.min is 160/108. now if you are sitting at either of these ranges then you definately need some chip tuning.
Also under WOT (PE) the ECM will also be in open loop=BLM 128
Hope this helps alittle.
Dennis
85 vette,383,miniram,ZF6,4.10's..best ET 11.81@117.00 60' 1.65
w/100HP nirous 11.05@127
http://geocities.com/bowtie8
Old Oct 19, 2000 | 05:15 PM
Yelofvr's Avatar
I beleive you are refering to the BLM "VALUE". I am talking about the BLM "Cell number" My INT is set at 128( by ecm default for WOT)and my BLM value is 134. Thanks
Dave Zelinka
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
THX181
Aug 6, 2015 10:21 AM
