what would I need to burn my own chip?
Old Oct 22, 2000 | 11:00 PM
formula5's Avatar
I would love to get into burning my own chips.What hardware and software is required and whats the cost?My brother has a 89 daytona turbo, is there any way to do his car too?
Old Oct 23, 2000 | 12:20 AM
Blade's Avatar
Check out the technical article on this very topic on the main site.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 23, 2000 | 04:33 PM
gravitar's Avatar
This isn't really on topic I guess, but has anybod with an extra ECM set one up as a dedicated "chip reader station"? I recall somebody doing a write-up on what wires to connect, but I haven't been able to find it recently. I would guess you'd only need to hook up the power and serial lines, no? I was thinking I'd maybe wire up the SES light, just to indicate that the ECM is alive.
Since I have 3 ECMs and my chip writer is an ISA card in a desktop computer (too bulky to haul out to the car!), I'll use the computer and spare ECM as a "read/write center". My first goal will probably to get the '89 305TPI code to work on my '86..
Old Oct 25, 2000 | 08:53 AM
gravitar's Avatar
anyone?
Old Oct 25, 2000 | 04:10 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
gravitar,
Do you mean an ECM Bench? An ECM bench is where someone mounts an ECM and its harness to various sources to allow the ECM to run as if it were in a car. You can hook up diacom and view parameters. This is an awesome way to test different bins.
If this is what you are looking for then check out GRUMPY's info at...
http://www.diy-efi.org/gmecm/projects/ecm_testbench/
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 26, 2000 | 08:33 PM
gravitar's Avatar
I wasn't actually planning anything that ambitious, at least for now. What I'd like to do is, since my first actual PROM project will most likely be to take a factory '89 305TPI A4 chip and make it work on my '86 setup (remove VATS and maybe a couple other tweaks), I was thinking about setting aside an ECM for doing nothing but powering up the PROM carrier, and allowing me to download the contents of the PROM via Craig's MAX232 board and his software. I could then edit the areas of the code that need it, write it to a new chip using my PB-10 programmer, and pop it back into the ECM to verify that it wrote correctly. I'm thinking that all I'd need to do is hook up power and ALDL lines to the ECM, and I should be good to go.
Is this a good assumption? I shouldn't have to "emulate" any sensors or provide any other signals to the ECM to make it run in that minimal configuration, should I?
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
