Just to clear things up....
Old Nov 2, 2000 | 09:59 AM
Blade's Avatar
When your BLM is high, like in the 140-150 range that means you're running on the rich side right ? I'm trying to decided what to do to get em lowered at idle. Either lower or increase the values in the VE table... I guess if I'm running rich then I should lower those values for less fuel huh.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Nov 2, 2000 | 10:08 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
[B]When your BLM is high, like in the 140-150 range that means you're running on the rich side right ? I'm trying to decided what to do to get em lowered at idle. Either lower or increase the values in the VE table... I guess if I'm running rich then I should lower those values for less fuel huh.
No, that's lean, and the injectors are being corrected to stay on longer.
145/128 will give ya a rough percentage on how much to change things.
Old Nov 2, 2000 | 10:21 AM
Blade's Avatar
Oh okay.... That would explain the weird but cool sounding idle. It sounds like a locomotive at idle. LOL Well I guess I'll add more fuel and see what happens! Thanx!
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
Bob88GTA
Aug 18, 2015 03:31 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
