Miniram on now I have tip in stumble
Old Nov 1, 2000 | 08:12 AM
89vette's Avatar
Hi car is 89 Corvette 165 ECM with a miniram, CNC'd heads and mild crane cam. I had a Super Ram and just switched to a miniram. Wow what a difference. I love the miniram. I have a tip in problem though wehn cold and in open loop. The car starts and idles fine but it you goose it, it has a stumble and sometimes backfires through the intake. I checked for vacuum leaks and everything looks good (16-17inches of hg). Timing is at 8 degrees and fuel pressure at 48 psi (WOT). Plugs all look good.
What do I look at for this? What do I change? Should I increae the idle speed when cold? Block learns at idle look good in closed loop. What can cause this?
Thanks,
Jason
89 Vette 6 speed
CNC heads, crane cam, Miniram, headers
Soon to be 396 Small Block!
Old Nov 1, 2000 | 09:15 AM
87Z-ya's Avatar
I have this same exact problem with my setup, and its not the timing. Your car is running to lean, so is mine. Bump the fuel pressure up to 60psi and that stumble and backfire goes away. But if you leave it that high for a long time the injectors dont like it(2 of mine took a dump).At first ithought it was a vacuum leak, it wasnt and I played with timing for a long time and never got rid of it. To totally get rid of the hesitation and backfire i unhooked the o2 sensor from the ecm and lowered the pressure to 52psi(this is with the vacuum unhooked). For some reason unhooking the o2 wire makes my car run a little richer. Of course this is just a bandaid. The car really needs to be reprogramed for the miniram.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Nov 1, 2000 | 09:40 AM
89vette's Avatar
Hi,
My stock injectors won't take any more than 50 psi and then they begin to shut down and actually deliver less fuel. I have a new set of FMS 30lb units for the 396 when I install it. Glad to hear I'm not the only one with the problem I guess I need to richen the idle mixture and see what happens.
89 Vette 6 speed
Old Nov 1, 2000 | 09:59 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Access the Pump Shot table in the PROM and modify it with about a 20% increase. If that doesn't work then jump to a 30% increase, then finally a 40% increase.
I had a similar problem and ended up using a 40% increase (changed the 25% values to 35%).
I am NOT saying that this will work for you ... but, it did work for me.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Nov 1, 2000 | 10:05 AM
89vette's Avatar
Hi, do you have the address for the pump shot? My GMEPro epe file does not show these so I guess I need to do a direct edit. What are the decimal values? A percentage increase of idle fuel?
Jason
89 Vette 6 speed
Old Nov 1, 2000 | 11:14 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by 89vette:
Hi,
There has been repeated testing (Kinsler's) showing most the gm injectors will run up to 90 PSI, and the syclones (nothing special) have run linear up to 110 PSI. Don't forget as you raise the fuel pressure, the fuel volume drops. A fuel pump can do only so much work. If you raise the pressure and go lean probably the pump, and life expectancy of a pump drops as the pressure goes up
Old Nov 1, 2000 | 11:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Is this is all when cold, then the cold enrichments are off.
What are you BL numbers when warm?
You might work on changing the injector constant, rather then the FP.
The Miniram is gonna change the way the cylinders are filled is very short runners, and if you really wanted it right I look at the scaler and MAF tables, trouble is they are real easy to screw up, you need a *good scanner* to get into the MAF stuff, and a fat note book.
Thanks,
Jason
Old Nov 2, 2000 | 07:44 AM
89vette's Avatar
Grumpy I disagree with you on the injector pressure. At idle, if I turn the fuel pressure past 50 psi the block learn goes way up and the car will hardly idle. At 60 psi it won't start (plugs dry). Maybe its just the multec's. The backfire happened yesterday while in closed loop and driving. I was driving normal shiftign from second to third. Slight hesitation...POP....and then all is good. My block learns are 126-130 at idle. If you change the injector constant would you change it to a lower value than 22pounds so the ECM adds more fuel?
89 Vette 6 speed
Old Nov 2, 2000 | 10:04 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
[QUOTE]Originally posted by 89vette:
[B]Grumpy I disagree with you on the injector pressure. At idle, if I turn the fuel pressure past 50 psi the block learn goes way up and the car will hardly idle.
You crank the FP up, and the BLs go up?.
BLs should go down.
If they go up that means your running low on fuel, which can suggest that the pump is shutting down. I'd be more suspect of a pump going south.
Gosh, hope no one uses them in a boost situation of 15 PSI with a intial setting of 43 or so....
If this was right during after the gear change might look at the timing, first.
Yep.
BTW, No need to argue, just go over the archives at the syty.org list, and research it your self.
Was about 2 years ago.
Cheers
Old Nov 2, 2000 | 10:41 AM
89vette's Avatar
Hi Grumpy. Are you Bruce Plecan from the GMECM list? I can make it pop by just goosing the gas in neutral so its not just after a shift. As far as the injectors go saying that I disagree with you was not a correct term. I didn't mean to come across that way. My fuel pump was replaced last year. It's proabably just my style injectors. I'm going to add 10% of fuel or so to the first 7 or so MAF table values and see what does. I'm running a gutted MAF and I hear they under report airflow. One thing I noticed is that for some reason the car starts really fast now as compared to the TPI or Super Ram set up.
89 Vette 6 speed
Old Nov 2, 2000 | 11:15 AM
TRAXION's Avatar
89,
Before making any PROM changes I would suggest 3 things ....
1) Doublecheck your initial timing (with the EST signal disconnected of course). This is of paramount importance because you don't want a dumb timing issue affecting your car.
2) Verify that the FP at WOT is steady. Hook up a FP guage and duct tape it to your windshield. Go out with a friend and have the friend watch the FP over a brisk WOT run. It should be steady and not decreasing.
This will verify that your pump is up to the task ... yes, I know you just replaced it but it doesn't hurt to verify it.
3) Make sure your car is in a good state of tune. Good plug wires, good cap/rotor, good plugs. An ignition issue could easily cause this problem.
Tim
Old Nov 2, 2000 | 12:30 PM
89vette's Avatar
All good advise Tim. I did double check the timing and had it from 4 to 8 degrees. Its set on 8 now. I also played with fuel pressure 42 to 50. It's at 50 now. I didn't do the WOT thing with the fuel pressure becasue the problem was a low speed thing. I'll do it though.
89 Vette 6 speed
RedLeader289
May 28, 2019 01:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
