Newbie
Old Nov 10, 2000 | 01:15 PM
dgoodhue's Avatar
Newbie
I just recently found your forum. I think this PROM forum is great. I am planning burning my own PROM when I swap in a 383 into my car.
I have an 86 Corvette with the 165 ECM. I have access to a Prom burner & Ereasor. I own a Diacom. I assume I need an apdapter to fit my memcal and an editing Program.
On the Memecal, am I going to reprogramming all three chips in the carrier?
I have a TPIS Stage 4 chip (and a stage 3) I notice alot of member looking around for programs, Will an editing program read in (convert) the TPIS porgram so that I can modify it? If I can read in the TPIS program, Should upgrade ($75) to the Stage 5 program and use that as a baseline or should I just save my money?
Dave
86 Vette Conv.
Old Nov 10, 2000 | 02:49 PM
Blade's Avatar
Originally posted by dgoodhue:
[B]I just recently found your forum. I think this PROM forum is great. I am planning burning my own PROM when I swap in a 383 into my car.
Great idea!
The easiest way to do it is to desolder the existing EPROM on your carrier (the biggest chip that has a window in it), and solder a ZIF socket in place. That way you can swap EPROM chip very easily in a matter of seconds.
Nope. Just one.. The big one with the window in it. It's called an EPROM (Eraseable Programmable Read Only Memory)
Yes. Once you download a program like GMEPro, TunerCat or WinBin you'll have to read your current TPIS chip, dump it to a file then open that file in your editing program.
Definetely save your money! Although 75 dollars is cheap for a little more you can make any modifications YOU want, and do it as many times as you heart desires, not just once.
For starters go read the EPROM Burning article posted in the tech area of the main website. It's a very good starting point especially for people trying to get started in burning their own eproms.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
rubblerubble
Mar 13, 2016 06:57 PM
R3500
Aug 24, 2015 09:05 AM
jeepman
Aug 17, 2001 08:13 AM
83Z28
Carburetors
Jan 5, 2001 05:15 PM
