Pc Interface
Old Dec 28, 2000 | 06:42 PM
1989CamaroRs's Avatar
Pc Interface
is it possible to bypass the prom and hook a laptop up the ecm, so you could change info without burning a prom. Also does anyone make a computer based scanner to hook up to the aldl?
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
-SSM Subframe Connectors
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
Old Dec 28, 2000 | 11:29 PM
InTech's Avatar
You can pretty much do anything you want if you want to spend enough money.... A real time emulator(with dual ported ram) will allow on the fly changes but now you are working in hex...no fancy tunercat software will allow updates..so you better know what you are changing....I think accel has a piggyback computer that will allow SOME real time changes(never used one) As far as the datastream goes there are quite a few such as Diacom and Autotap...just the tip of the iceberg but can get you lot's of results....sorry I don't have any handy hyperlinks... ttyl
-Carl
Old Dec 29, 2000 | 06:46 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yes, you can bypass the eprom. Need a devise called a prom emulator. They start at 200ish, and go to 700. Outfit in Australia called Kalmaker that sells a rig for using with the 808. Again too pricey in my opinion.
Diacom, and The Turbo Shop sell ALDL scanners. There are lots of others thou. I found a used Diacom + some years ago, and have been happy with it. But, on the early and TBI it has it's limits. I wouldn't be surprised to see a 747 edge board scanner thou in the next few months...
Old Dec 29, 2000 | 08:09 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
To keep this as simple as possible....
No. There is no way that you can change your calibration without burning a PROM. PROM emulators and software like Kalmaker just let you close in on your calibration without burning multiple PROMs. However, in the end you will still have to burn a PROM and swap it with the one currently in your ECM. I believe that you are referring to systems such as the 94+ 4th gens that have EEPROMs. These types of PROMS are electronically eraseable and therefore can be reprogrammed while STILL in the ECM. However, our PROMS are only erasable via exposing to UV light.
With all that said ... I bet that someone could probably come up with system that COULD accomplish this. It is a well known fact that you can replace the standard EPROM in our cars with an EEPROM. That's great because then you never need to use the UV light. Also, electronically erasing PROM is darn quick as compared to standard EPROM UV erasing. Hmmmmm.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
350tbi
Apr 15, 2002 11:31 AM
jnjspdshop
Apr 12, 2002 11:03 PM
Christos
Nov 16, 2001 06:47 PM
