Does VATS only disable fuel???
Old Jan 17, 2001 | 04:46 PM
tpic1500's Avatar
Does the vats only disable the fuel pump or does it disable anything else in the ecm? Does it keep the injectors from pulsing or keep the distributor from sending a pulse signal to the injectors?
Nick
Old Jan 17, 2001 | 06:11 PM
87/88Firetruck's Avatar
As far as I have gathered, the VATS affects two things:
1. Starter relay
2. Injector pulse
Since you are probably using your stock starter wiring, the relay control is negated. As I understand, the factory starter wiring in VATS equipped vehicles incorporated a relay which must be closed by the ECM before power can be delivered to the motor.
I believe that there is a two second delay after the vehicle starts in which the ECM "listens" for the VATS module signal, which we are trying to emulate. If it does not recognize this signal, it stops pulsing the injectors, and the engine dies. This is where I had trouble. I do not believe that the fuel pump is manipulated in the process.
Old Jan 17, 2001 | 06:16 PM
tpic1500's Avatar
I also believe that the ecm will not pulse the injectors until the vats is disabled. I can turn my engine over but I am not getting any pulses to the injectors. I checked everything else that i could think of. I do have spark, but no injector pulse from the distributor.
Nick
Old Jan 17, 2001 | 06:30 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well it all depends on witch one you have I or II in know I only controlls the fuel pump not sure on II I will have to look it up.
Old Jan 17, 2001 | 06:36 PM
tpic1500's Avatar
My ecm is out of a '91 Formula. ECM is a 7730. Appreciate any info. you may have.
Nick
Old Jan 17, 2001 | 06:50 PM
Engine: ls1, LB9
I can only take a guess but, it may be vats II ??? none of my books here say I would have to check at work.
Old Jan 17, 2001 | 07:11 PM
tpic1500's Avatar
Just read info. about VATS at www.jimsperformance.com . It is true, the vats does disable the injectors until it receives the necessary signal. Check out that site, it has a lot of info. and neat stuff. Jim is a great guy and has been very helpful.
Nick
Old Jan 17, 2001 | 07:25 PM
Engine: ls1, LB9
looks cool I will have to spend some time there.
Glowsock
Jul 24, 2025 03:15 PM
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
ezobens
Aug 19, 2015 10:29 PM
djmarch
Aug 9, 2015 05:27 PM
