Bad Memcal or what?
Old Jan 17, 2001 | 07:24 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Bad Memcal or what?
I have the stock GM Memcal and one with the ADS superchip, both modified with sockets to swap Eproms easily. I started with the ADS memcal, since I put a ZIF socket on it. I started out by making a copy of the GM prom and another of the ADS prom, just to see if everything worked.
I started the car with the ADS memcal, and th e GM chip copy. The car ran, but not very good, and the SES light stayed on. It probably was running in "limp-home" mode. I could not get any codes out of the ECM either. I tried my stock chip, as well as the original ADS chip, and the same results.
So, I pulled that memcal, and tried my GM memcal with the GM chip in the socket. Car ran fine with no codes. I also tried my 2 "newly" burned chip copies, and they both worked fine. What could have happened to the ADS memcal? Do they go bad, or perhaps maybe I damaged it during the work I did on it?
Now another question, is it ok to swap EPROMS and/or memcals with battery voltage applied to the ECM? (key off of course) I don't think it would hurt anything, just wanted do get some opinions. Thanks.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Jan 18, 2001 | 03:05 AM
InTech's Avatar
It will not "hurt" anything electrically, but you want to unplug the computer for at least 10 seconds to clear the ram. Ohm out your memcal pins to zif socket, should find prob there.
-Carl
Old Jan 18, 2001 | 10:58 AM
Blade's Avatar
Some people will tell you it'll "hurt" your ECM to swap chips while the battery is stilll connected, but as far as I'm concerend as long as the key is off, the ECM is turned off, so it's safe. I've done it for a few hundred times on my car with no problems... hehe
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 18, 2001 | 06:47 PM
Car: 1988 IROC-Z
Thanks for your replies. I guess I could unplug the power fuse for the ECM, since it is easy to get to. But I will most likely just swap out the eproms with the key off, and everything else connected.
I found the problem with my ADS memcal and ZIF socket soldered in. The socket itself had 4 sockets bridged across on 1 side, and 2 bridged on the other. These were on the top of the socket where the chip goes in. It was definitely a manufacturing defect. I kind of figured that the ZIF was a low-qualitiy socket. Just have to check everything out twice over I guess. An exacto knife fixed it easily. I tried that memcal in my car tonight with 2 different eproms, and it worked fine.
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
lethaldomestics
Sep 21, 2015 01:18 PM
gta892000
Sep 16, 2015 12:40 AM
RyanJB
Sep 2, 2015 01:27 PM
