Running the $8D on the 165 ECM
Old Jul 5, 2006 | 02:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Does anyone have an $8D AUJP bin that they converted to run on the 165 ECM (1986-1989)?
I don't want a bin. I was just wondering if it has already been done.
Old Jul 5, 2006 | 03:44 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I doubt it. I think the hardware is different enough that you would need to rewrite a ton of things to make it work. I do know there are quite a few guys running the holden (think its $5D?) code which is MAP based, and used on the '808, which is the '165 without the 8192 baud chip in it.
Old Jul 7, 2006 | 11:56 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I kind of figured that, but I was putting it out there to see if any one else was interested in working on it.
I talked to a few guys that are running the Holden code. I like the $8D code better though.
Old Jul 8, 2006 | 10:49 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Patch in the stuff that you like from the 8D to the Holden code.
Old Jul 8, 2006 | 12:12 PM
ScotSea's Avatar
GM may have done it for you. I picked up a 1992 AWD Astro van ECM (PN 16156647), and it uses broadcast code BCBC1250. It sure looks like a 165 ECM, and the code looks similar to $8D. The code ID is $D5.
Just need to know if the 16156647 and 165 are compatible, or at least near compatible. If near compatible, it would prbably be easy to get it to run in a 165.
Scot
Falcon50
Aug 22, 2020 03:26 PM
Elephantismo
Feb 13, 2019 12:51 AM
69GTOby
Apr 18, 2016 02:34 PM
customblackbird
Oct 1, 2015 04:30 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
