87 vss, is it 8000 ppm, then knocked down to 4000 in 7730?
Old Jul 6, 2006 | 02:00 AM
87_TA's Avatar
Sorry,
Should know this buy have forgotten.. just swithed to th350 and looking for a vss to hook to cable output.. just can't remember what pulse per mile they are..
Are they 8000, then knocked down to 4000..
Anyone know of any good retro vss's?
Old Jul 6, 2006 | 07:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The mag sensors in the transmission is 4000 ppm. For the MAF cars the 4-out buffer divides it by 2 for 2000 ppm to the ECM. The SD cars have the VSS signal fed directly to the ECM.
Earlier cars used an optical pickup mounted to the back of the speedometer. This is a 2000 ppm and drove the ECM directly. If you still have a speedo you may be able to retro fit one. I'll bet the mounting point on the speedo is still present on the cable driven ones. then it is 3 wires: ign switched +, ground, and signal to ECM.
I don't believe a 700r4 vss will fit the th350, however, here are some interesting options:
D8A: OE #10456131 has a cable output and a signal output.
D8B: OE #10456132 looks to be the same as D8A.
RBob.
Old Jul 6, 2006 | 08:39 AM
87_TA's Avatar
RBob.
Thanks Rob,
I know the vss does not fit - But I bought a cyberdyne retro fit, its 8000 ppm and has 3 wire hook up.. Guess thats why it does not work.. And I think its ac and ours are dc.
Thats pretty cool with the optical on back of speedo, but I just get the right
vss.. thansk.
Old Jul 9, 2006 | 02:15 AM
Z69's Avatar
Z69
Jaguars That Run sell cable/vss modules.
I picked one up for my T350.
Just call them, it's easier, and they don't sell the little extension cable anymore even though they list it...or used too.
Did you get my PM a while back????
Old Jul 15, 2006 | 04:33 PM
87_TA's Avatar
RBob.
Well,
10456131 just came from parts direct - it ment to go into a 700 tail and have a cable output.. unfortunately I need the opposite.. But it looks like if I use an extention cable it should work..
Anyone know where to get the extention cable?
Z69:
Sorry,
I got your PM, Keep meaning to reply - You know how that goes..
Been busy with the BBC project, but since it broken right now back on this...
Old Jul 17, 2006 | 03:44 PM
Z69's Avatar
Z69
I know of a place in CA if you can't find one that makes cables.
Check with your local speedometer shop.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
