730 RETRO
Old Feb 4, 2001 | 04:24 PM
MR.HP's Avatar
730 RETRO
I AM installing FI on 55 chev I need to Know
What SHOULD BE TURN OFF IN PROM.I HAVE VSS
BUT NO EGR,I'AM WORRIED ABOUT CANS.PURGE,
AND OTHER FLAGS I WANT TO MAKE SURE IT DOES
NOT GO L/HOME MODE. THANKS IN ADV.
Old Feb 4, 2001 | 11:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
If you read programming 101 at DIY_EFI, then check back, I can tell ya where you need to do it. Kinda hard to explain the flags in 2 paragraphs.
Best is set something in the parameters so things aren't enabled, rathen then just resetting flags in my opinion
Old Feb 5, 2001 | 07:41 AM
MR.HP's Avatar
[QUOTE]Originally posted by Grumpy:
[B] If you read programming 101 at DIY_EFI, then check back, I can tell ya where you need to do it. Kinda hard to explain the flags in 2 paragraphs.
THANKS GRUMPY FOR REPLY.I Have read Programming 101,Tuning Tips,ANYTHING else I can get my hands on.You are the one that got
me thinking about parameters instead of just
Flags.I can find EGR TEMP in WINBIN and a few
others I also have a Reg. TUN Cat. I don't no
what all I should turn off.Like EGR should I set TEMP to 254 OR off at 255.I want to be able to use Hiway mode FUEL.AS I understand you need VSS for that and some other things
ANY HELP WOULD GREATLY APP. THANKS
junkcltr
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
HighHopes85
Dec 3, 2001 06:28 PM
