Stock 87 vs Stock 88
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
A new friend on this board sent me his BIN for his '88 350 TPI (I also sent him mine). Comparison revealed several areas of differences:
1) Both spark tables
2) Max Knock Retard
3) All four fuel/air ratio tables
4) Target IAC idle speeds
Some of the differences are quite dramatic. 88's had a little stronger cam, but otherwise are the same as 87's, AFIK. Are there any other differences in the engines that I don't know about? Could these differences simply be refinements / improvements that GM made for the new model year?
I am inclined to believe that the latter is the case. Since the cam I am running is similar to the '88 cam (slightly more duration, a good bit more lift) I am heavily leaning toward using the 88 chip as the baseline in my car and making modifications from that, instead. What do y'all think of that?
'87 IROC 5.7l TPI - original owner!
2) Max Knock Retard
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by P J Moran:
2) Max Knock Retard
</font>
2) Max Knock Retard
</font>
Engine: 5.7l TPI
Axle/Gears: 3:23?
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
I've yet to see a newer cal that is worse then an older one. Thou for a specific car that Might happen. For the MAF cars start with the 89 code. Much better, IMO
</font>
</font>
Genopsyde
Oct 7, 2015 08:35 PM
