Where to get connector for ALDL interface cable
Old Feb 6, 2001 | 08:36 AM
shawn87gta's Avatar
I ordered the MAX232 sample chips and I'm interested in making an interface cable to connect to a laptop. Where can I get the ALDL connector? Is this a standard connector available from places like Digikey? Any suggestions for software for scanning with a laptop?
Thanks,
Shawn
Old Feb 6, 2001 | 05:33 PM
leirch's Avatar
Shawn,
Good question, if you find out, let me know! I need one also.
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 6, 2001 | 08:48 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Go to you local discount store like Wal-Mart. In the auto section they have a cheap code scanner for around $20(GM). Gut this thing and put your homemade stuff inside the case, attach a printer cable with the printer end cut off and you have a professional looking scanner cable.
I have done this same thing.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Feb 8, 2001 | 01:13 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Check with Andrew at AKM Electronics. Here is his website. www.mindspring.com/~amattei/akmelect.htm
[This message has been edited by TC602 (edited February 08, 2001).]
wigmobile
Feb 26, 2025 02:56 PM
L0tuS
Oct 4, 2015 08:07 AM
gta892000
Sep 16, 2015 12:37 AM
greenyone
Sep 8, 2015 08:41 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
