HELP! EPROM will not erase
Old Feb 12, 2001 | 08:23 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I've had my Hypertech EPROM in the UV eraser for about 24 hrs total. First try was about 1 hour. Then I tried to program it. The pocket programmer on a blank check said that the EPROM was not erased.
I checked that the light bulb comes on, it does. I put the EPROM back in the eraser for about 4 hours on each side and it still did not erase according to the procket programmer.
This EPROM has two circular spots on both sides, but no square or rectangular window.
I did remove the tag on the top side of the EPROM.
What can be wrong here?
TIA
doc
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Feb 12, 2001 | 08:29 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If there is no quartz window on the EPROM then it is not an EPROM ... but, a PROM. If it has no quartz window then you CANNOT erase it. Go to the link in my article all the way at the bottom that discusses how EPROMs/PROMs/EEPROMs work.
Tim
  • Program your own PROMs!. Read my article to get started!
  • Research and Experiment before asking questions.
  • This is not a chip store. Go to the classifieds if you want someone to sell you a chip or give you a BIN.
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Feb 12, 2001 | 10:11 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with Traxion; now "windo" means it is not a Eraseable EPROM. Sorry to hear that; but I am finding that many of these aftermarket "chip manufacturers" are very inconsistent on how they do the chips.
I know that with ADS some people have a removable chip, while others (like me) has theirs soldered in.
Time to "unsolder" the chips and replace it with a ZIF socket.
Old Feb 13, 2001 | 01:58 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by doc:
TIA
doc
Pocket Programmer expects an erased chip to be all 00's, some chips erase to FF's. So while erased, Pocket Programmer doesn't see them as erased. Get another EPROM, and try. GM EPROMs are really bad for this..
</font>
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
the_nikfive
Aug 11, 2015 02:46 AM
mike89z
Sep 5, 2002 10:53 AM
leirch
Mar 2, 2001 09:06 PM
David 91RS/Z28
Oct 6, 2000 08:41 PM
