would this throw a code/can I take it out?
Old Feb 26, 2001 | 09:54 PM
Spyder's Avatar
Okay I have a 92RS with a LO3. I was considering doing this mod
https://www.thirdgen.org/newdesign/t...rpentine.shtml
my question is removing the smog that would throw a code correct? Would it hurt my car/cars performace to do that? Could I program a chip take it out? I'm sorry I'm very new to the idea, please bare with me. Thanks guys!!!
Josh
Old Feb 26, 2001 | 10:41 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Spyder,
No problem. I did this same mod a couple years ago. No codes. Everything is AOK.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Feb 26, 2001 | 10:42 PM
Spyder's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
Spyder,
Tim
</font>
Really did you notice any more power out of the deal?
Old Feb 27, 2001 | 02:32 AM
93ND500's Avatar
If you have problems finding the right belt, tell them it is for a 1993 Chevy C1500; 350; No A.I.R.
I swapped out my trucks TBI for a TPI system. Also had to use the 92 F-Body s-belt setup. My kit did not come with a new belt, so I just tried my trucks belt and it fit nicely.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Old Feb 27, 2001 | 07:40 AM
TRAXION's Avatar
The only reason that I removed emissions stuff is because it is in the way. If GM would have designed a system that wasn't in my way when I had to work on the car then I would have left everything intact. So - no power difference - but A LOT easier to work on your car.
Tim
Old Feb 27, 2001 | 02:38 PM
Spyder's Avatar
Humm, I'm getting sick of all the crap that is in my engine bay, another guy on here has a way to bypass the AC to. I wanna pull all of it.. I just want "the motor" thats it. I don't want to have to start a crash course in Prom Buring.. For some odd reason when you need it, you can't do it.
Old Feb 27, 2001 | 03:17 PM
The ODB's Avatar
my tests on V-belt cars show 5hp from removing it. No data on serpentine...didn't feel it was important since I know it helps to remove it.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
