ECM swap?
Old Mar 12, 2001 | 05:52 PM
85ZZ4TPI's Avatar
ECM swap?
I want to upgrade from my 85 mass air to a sd7730 for tuning raesons. I am wondering about patching a 7730 into my 85 harness?Possible?I dont want to pay 300$ for a new harness.
Old Mar 13, 2001 | 07:33 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
See the write-ups at:
http://www.eecis.udel.edu/~davis/z28/
for the 2 swaps Mike Davis did. He first swapped from the '85 setup to the '86-89 ECM ('165), then went to the '90-92 ECM ('730).
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 13, 2001 | 05:47 PM
85ZZ4TPI's Avatar
How much of the wiring is existing that I can patch into the 7730? How much custom wiring do I have to do? Will my original diagnostic port work, Check engine light problems? Any more input is appreciated. Thanks
ZZ4 crate motor,Stock tuned port,afpr,700R4 art carr shift kit,3.42 posi drums,Eibach pro kit,poly bushings throughout,yadayadayada
Old Mar 14, 2001 | 12:18 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 85ZZ4TPI:
</font>
Last one I did was about 4 hours (c3 to p4).
Get the harness ends, heat shrink, and some spare ecm end connectors at Pep boys, Then match up the wiring, If you wire things up right all should be just at is in a 730 car. Just watch the speedo hook up.
Old Mar 14, 2001 | 07:15 PM
85ZZ4TPI's Avatar
Grumpy, Speedo? The Ecm works with the speedo? How much time for a beginner with a wiring diagram?
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
