Chip Gurrus please help
Old Mar 17, 2001 | 10:44 PM
Mike635's Avatar
Have 24lb injectors in my 350,while im collecting parts for new motor,chip is by Howell,well failed my smog check at low and high,way too rich.If install my 22lb injectors would i mess anything up? And chip was burned for 24lb inj,in 350. Thanks Mike
Old Mar 18, 2001 | 10:24 AM
Mike635's Avatar
And i passed visual and mechanical inspection of emission equipment,just way to rich.At 2500 rpm,HC max 0180,mine 0154 CO max 1.00,mine 3.49.CO2 9.8,O2 4.6 / At idle,HC max 0120,mine 0218,CO max 1.00 mine 3.04,CO2 10.5,O2 3.8,rpm 728. Anybdy?
Old Mar 18, 2001 | 10:37 AM
Blade's Avatar
If you install 22's it will run leaner which should be a good thing for you. As far as "messsing anything up"... I don't see any problems with that.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 19, 2001 | 12:00 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Mike635:
And i passed visual and mechanical inspection of emission equipment,just way to rich.At 2500 rpm,HC max 0180,mine 0154 CO max 1.00,mine 3.49.CO2 9.8,O2 4.6 / At idle,HC max 0120,mine 0218,CO max 1.00 mine 3.04,CO2 10.5,O2 3.8,rpm 728. Anybdy? </font>
How long since your last oil change?.
Might have a bad plug wire.
How hot was the enigne?.
In the test manners you mention, the ecm is trying to run at 14.7, and for some reasons can't.
For emissions testing you want a Hot engine, decent tune, fresh oil, high as possible idle speed (ie just with in limits).
Numberous fuel additives also to help you pass
Old Mar 19, 2001 | 01:22 AM
Mike635's Avatar
I did a tune up and oil change before i went, also found out here the svo inj are rated higher,i didnt know that,now my fuel pressure at idle 36 instead of 42. Idle was fine,but will check plug wires could have a lame one,would switching back to 22lb for retest work. Whether vehicle was properly warmed up is a hotly contested item between me the smog guy and the owner of the shop.Even though i have my B.A.R sticker(it did pass their test)i had to install computer controlled cannister instead of only vacuum.Well the smog guy just rolled his eyes,and i could tell he didnt want to deal with it,my vehicle sat outside at least a half hour before being tested,i never saw him drive it so i would assume that as soon as it went closed loop he tested.So now im a gross polluter.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
