Is there a way to control knock sensor sensitivity?
Old Mar 11, 2001 | 08:56 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
For a '92 5.7 TPI?
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Mar 11, 2001 | 09:20 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes.
Knock Attack Rate vs RPMs
Knock Recovery Rate vs RPMs
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Mar 11, 2001 | 10:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There is also a Maximum Knock Retard vs MAP and Max Knock Retard vs RPM. It is useful to also use these because I found that if you get too aggressive and put too low of an attack rate and/or too high of a recovery, you may have knock occuring but the ecm keeps removing the retard even though knock is occurring; thus making REAL knock occur.
So I found a slightly less aggressive attack/decay rate with a "cap" works better.
Also, I just found another knock retard in the "octane" routine that almost permanently retards your spark. I am still investigating this, but I found that by adjusting the "recovery amount", "maximum retard amount" and the kpa "threshold", you can make this retard recover very quickly (provided no further knock occurs).
Old Mar 11, 2001 | 10:33 PM
2QUIK6's Avatar
Thanks for the info. I'm getting upto 15 degrees sometimes because of a rod/bearing knock and I'm trying to figure out a way to skirt the problem for a while till I can tear into it, short of removing the knock sensor all together.
Old Mar 14, 2001 | 12:43 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
Yes.
Tim
</font>
Not to nitpic, but those have nothing to do with the actual sensitivity of the system. Just how the ecm reacts to the sensor.
In the MEFI applications they use a 45d male to female fitting adapter to dampen the K/S mounting.
On my car I have a T fitting with a early and late K/S so I can switch to various ecms.
In any serious tuning, you have to double check for detonation with plug readings
Old Mar 15, 2001 | 12:12 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I found a schematic (on some other message board) that includes a series of resistors that can be installed in the line to the knock sensor. It supposedly "muffles" the signal and effectively desensitizes sensor. I don't know if it really works, but have installed it on my car.
According to my scan tool, some knock is still being detected and the timing is getting retarded by as much as 9* in some cases. No matter what changes I make to my timing tables, I can't get this to go away.
I brought this up in a post (now a thread) in the General Engine board https://www.thirdgen.org/messgboard/Forum7/HTML/005943.html. Glenn tried to help me there, but I'm stuck because I can't change those parameters on my bin with TunerCat.
At any rate, if you're interested in the schematic, let me know, and I will try to find the link to it.
'87 IROC 5.7l TPI - original owner!
[This message has been edited by P J Moran (edited March 16, 2001).] (Fixed the link to the other board thread...)
Old Mar 15, 2001 | 12:28 PM
InTech's Avatar
I have never done it but you could probably use something like a 22uf(or higher) capacitor to change the wave form a little which should have some dampening capability.
-Carl
Old Mar 15, 2001 | 02:35 PM
Car: Death Mobile
Engine: 666 c.i.
PJ, if you know the addresses, you grab a trial offer version of TDF Editor from TunerCat to create a "constant" or "table" within your TDF. This is how I initially added certain tables and constants to my 8D tdf when they were not defined.
In fact, I was so impressed with TDF Editor that I ended up buying, I found it so invaluable.
Old Mar 16, 2001 | 08:10 AM
P J Moran's Avatar
Engine: 5.7l TPI
Axle/Gears: 3:23?
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
</font>
As I understand it, I need a hack in order to know the addresses. I don't have the hack for a $32B (or any other, for that matter), so again I'm stuck. I would like to get the hacks for $32B and $6E.
I have downloaded it (the TDF editor) and I'm sure I would come to the same conclusion, but it's useless to me right now.
Old Mar 17, 2001 | 08:34 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by P J Moran:
</font>
There are 4 generations of K/Ss that I know of, so unless your using the right generation strategy, you might generate some real problems by having toooo much of the signal detuned.
Some folks like trying to throw software cures for mechanical problems, I tend to use mechanical corrections for mechanical problems, etc
Old Mar 19, 2001 | 08:12 AM
P J Moran's Avatar
Engine: 5.7l TPI
Axle/Gears: 3:23?
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
</font>
Are you implying that I should look at using a different sensor? If so, what would you recommend? I am using my original sensor, now.
Or are you saying that I should work on the engine tuning to solve the problem? Changing (reducing) the timing hasn't helped.
Old Mar 19, 2001 | 09:49 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No, just that the schmatic you have might do more harm then good, if not for the right sensor
You need to figure out the cause of the problem, if you have a rod knock, well, you'll never get rid of the K/S being triggered, other then entirely disabling it. If from a serpentine belt then the belt needs replaced.
If you just need to **de-tune** it a little, the use a 45d male to female fitting, and reinstall it with the sensor pointed *up*
HTH
</font>
Hotrodboba400
Dec 10, 2019 07:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
willyjoejr
Sep 3, 2015 09:26 AM
masonta
Sep 1, 2015 06:40 PM
