would running lean at idle damage engine???
Old Mar 19, 2001 | 03:59 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
If the blm is at around 135ish in park and 130 in drive would any damage be caused. I was thinking that running a little lean with no load(in park) would not damage the engine at all. And would there be other times that one would want the blm to be a little lean??
Just curious to see what everyone thinks.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s.
Old Mar 19, 2001 | 05:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by mike89z:
</font>
It's not **lean**, it's taking a correction of enrichment to get to 14.7 is all.
Ideally you MIGHT want 128 but some engines for drivibility might like other then 128.
Old Mar 19, 2001 | 09:24 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
I meant when you first start when it is in open loop.
Old Mar 20, 2001 | 12:07 PM
Desert86Roc's Avatar
How are you determining a lean condition? What are your spark plugs telling you? You dont sound lean to me, 130 is a normal range that means the computer is not having to adjust much from whatever the programmed value is. At idle, my blm is 147, meaning mine is a lot leaner, and it is having to add more fuel to compensate.
Old Mar 20, 2001 | 08:19 PM
88GTASTK's Avatar
You'll have a miss if the ECM isn't compensating for the lean mixture.
Paul
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
