Will a 86 caprice chip work in and 86 z28? Same computer #
Old Mar 20, 2001 | 05:04 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I swapped in a gm 350 and instead of getting a coustom chip they said they have a chip for a 350 caprice and that they use the same ecm but the chip codes are diffrent. There not sure if it will work or not. (if not what should I do) What do you think? Thanks
The car has a Q-JET.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
[This message has been edited by BLACK Z (edited March 20, 2001).]
Old Mar 20, 2001 | 08:24 PM
RODS92Z's Avatar
You can use the ecm from the caprice but you will have to change the chip (prom).
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Old Mar 20, 2001 | 08:53 PM
BLACK Z's Avatar
Car: 86 Z28
My ? is can I use the chip the hypertech sells for a caprice in my camaro computer and in my camaro. does the computer read all of the sensors the same? Things like that.
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
matthew911
Aug 12, 2015 09:38 AM
