What is it called?
Old Apr 5, 2001 | 02:52 PM
Chris Sartori's Avatar
What is it called?
Hello All! I have the 1227730 ECM. But when I opened it up to see the PROM all there was is a long slot (like a Dimm slot in a computer) There must be a piece that the PROM plugs into then inserts into this slot.
Can anyone tell me what this piece is called and were can I get one? I will be ordering a PROM burner, eraser and EPROM,s soon. Need to be able to insert that EPROM right?
Thanks,
Chris
Old Apr 5, 2001 | 03:10 PM
Bob Wooten's Avatar
it is called a Memcal & if you do a search you on memcal, i bet you will find the GM part number. you ought to be able to goto your local GM dealer & pick one up (although he might have to order it for you. I think that you can order them from GM on line, bet someone here has a link.
if i am not mistaken, any V8 memcal (for a 7730) will work, 'specially if you are going to burn your own proms.
Bob Wooten
71 Camaro, 91 EFI, 01 HP
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Apr 5, 2001 | 03:53 PM
Brent's Avatar
Since the ESC is on the 7730 MEMCAL, it seems to me you should use one that came from an engine of the same displacemnet.
Old Apr 5, 2001 | 05:37 PM
Bob Wooten's Avatar
I may be all wet here but i dont think that it matters. I think that any V8 7730 memcal will work in any 7730. certainly you have to have a V8 one, as it has basically a cyl select that goes to the chip that controls timing.
BW
Bob Wooten
Old Apr 5, 2001 | 05:43 PM
Bob Wooten's Avatar
I just got this off of another email list.
16151348 is the gm part number for the AUJP1350 memcal. if i am not mistaken, this is 91, 350, auto,
Bob Wooten
Old Apr 5, 2001 | 05:57 PM
Bob Wooten's Avatar
Here you go. 1990-92 5.7 V8 TPI “8” L98. goto http://www.cruzers.com/~ludis/idxref.html & check it out. this guy has more information on GMECM's anyone ought to.
BW
Bob Wooten
Old Apr 5, 2001 | 09:30 PM
Thanks for all of the help! I will contact the local Chevy Dealerships and try to get my hands on one.
Again many Thanks for all the great advice and feedback.
Respectfully,
Chris Sartori
Old Apr 6, 2001 | 10:47 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Simply put - ALL of this information is in the tech article linked at the top of this page. Just read it
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
