Free software with cable i got
Old Apr 25, 2001 | 11:17 PM
BenDoe's Avatar
I got a cable from Ruse Electronics http://www.geocities.com/steve3034/cables.html and was wondering which of the free software would work with my 91 Z with the 730 PCM. I would prefer to have the ability to save my data. I was also wondering if this cable needs a power supply. Thanks.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Apr 26, 2001 | 05:32 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
My software should work fine for you -- I need more 730 testers out there!
Steve Ruse should be able to give you details on the power supply, probably you will not need one additionally.
-Craig
Old Apr 26, 2001 | 01:15 PM
Mojo's Avatar
Craig,
I'm hoping to have my system together in the next two weeks... I definitely appreciate the software and I'll be sure to give you any feedback...
Chris
408cid 1985 Corvette
http://www.mojosgarage.com
Old Apr 26, 2001 | 06:20 PM
BenDoe's Avatar
Is any body else out there running that cable with that software?
Old Apr 26, 2001 | 07:02 PM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
I am running that cable from Ruse Electronics with Craig's software. The software works great. I have the 165ECM but I'm sure it will work just as well with the 730. Let me know if you want a sample of what the log prints out or some screen shots.
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph
Minirammed 377 for spring
Old Apr 26, 2001 | 10:08 PM
james_fearn's Avatar
which cable listed on that page is the one that is needed?
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Old Apr 26, 2001 | 11:45 PM
BenDoe's Avatar
What if i build the "make it yourself" cable, could i still use Craig Moates software? the cable is found here. http://pweb.de.uu.net/pr-meyer.h/aldl.htm. And Why can't i download the free software that is on that page. I downloaded what i thought it was, and it didn't work.
[This message has been edited by BenDoe (edited April 26, 2001).]
wigmobile
Feb 26, 2025 02:56 PM
dbrochard
Sep 19, 2015 08:13 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
92firebirdguy
Sep 10, 2015 10:33 PM
scottmoyer
Sep 7, 2015 07:06 PM
