They offerd 4 chips in 86, which should I use for my 5 speed swap?
Old Apr 29, 2001 | 02:35 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I also have a 86, I was just wondering which i should use, they are all for the same computer, 2 are for 1 kind of 5 speed and the other 2 are for another. And I beleive they are all for carbed cars. I am going to order one from a company but they need the code and I need top know which chip so I can give them the code. Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
[This message has been edited by BLACK Z (edited April 29, 2001).]
Old Apr 29, 2001 | 03:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by BLACK Z:
</font>
Forget the aftermarket stuff. I tried them all some years ago.
The ZZZ retrofit electronics are what you want, they use a particular ecm knock sensor and prom.
Then get Doug Roes Q-Jet book, and then you can get the carb right...
There is a bunch of HP to be found in optimizing the secondary air door opening, needles and hangers.
Also, need to be able to accurately measure performance, even a stop watch. They are really picky.
Old Apr 29, 2001 | 05:30 PM
BLACK Z's Avatar
Car: 86 Z28
Yeah but the gm zz4 chip is for a auto, I have a five speed now, will the car go into closed loop witht he auto chip? thanks
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
