will i see CE light? EBL/Prominator install
i will assume it is likely. what may be the items i need to address to prevent or minimize the likelyhood of a CE?
IAT not yet installed yet but it is in my 8746 and wired and ready. i think i need to disable till i instal the sensor. right?
is there a disable flag in TP ?
Car: check
Engine: check
Transmission: check
In the doc it is under 'Malfunction Diagnostic Test Parameters' (table of contents).
Then the IAT has two entries: hi and lo failures.
In TP:
Malf Flags - 12 thru 24, IAT23 - intake air temperature failure, low
Malf Flags - 25 thru 42, IAT25 - intake air temperature failure, high
RBob.
In TP:
RBob.
