do i need to be a prom burner to run a miniram?
Old May 12, 2001 | 02:40 PM
bad camaro RS's Avatar
im not looking into burning proms now but i see alot of lean backfires and drivability probs with miniram and maf i dont wanna do proms now should i jus go with the superram? ive got a 87 355 tpi with 195cc afr heads and much more thanks Ron
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old May 12, 2001 | 03:46 PM
leirch's Avatar
Your going to have to do proms regardless, its just stupid not to. Think about it? Your running stock code that was designed for a STOCK motor... it can't possibly be correct or even close. I have the SR like i mentioned in your other post.
I don't have too many problems with backfire other than on decel... it seems to have fuel there. I'm using the MAF mainly and swapping SD in and out until i can get it tuned better.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
