Do I Need A Custom Chip to Run 24# Injectors?
Old May 15, 2001 | 10:27 AM
Mike 25th's Avatar
Just curious... I got the car back together and I am currently tuning it, but I have a dead spot in acceleration (right at beginning) as well as a surging idle and the SES light only comes on when I am below 1700 RPM. My sig explains all modifications.
Also, I lost some bottom end grunt - would going back to a stock TB replace some low end power?
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
SLP T-RAM Registry & Custom Decals Here!
Old May 15, 2001 | 12:37 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
What you need to do is read Traxion's article that linked at the top of every DIY PROM page, read as many of the previous topics on this board as you can, read the article again, then buy the equipment and burn your own chips. You really need a custom-burned PROM for your combination, but the only way it'll be done right is if you do it yourself.
Now to directly answer your questions. Yes, you need change the injector constant in the chip to match the flow rate of your injectors. If you bought the Ford SVO injectors, then they actually flow about 26 #/hr at the stock pressure TPI usually runs at (low 40's). The off-idle dead spot is because your engine is sucking in a lot more air and needs a much-biggger "pump shot", aka acceleration enrichment. What SES code are you getting? Replacing the TB won't gain you back any low end power, but tuning up your VE tables and adding some low-end spark advance will help tremendously, as well as a higher-stall torque converter.
Greg Westphal
'87 IROC 305TPI/A4
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
Exxon Limited
Aug 9, 2015 08:13 PM
