Will any 7730 Memcal work?
Old May 18, 2001 | 08:31 AM
89vette's Avatar
Got my 7730, pigtails, junk 165 and a memcal for my speed density conversion. The memcal has the ESC boad on it. It supposedly is out of an 87 Buick. Are all 7730 memcals the same?
Old May 18, 2001 | 08:51 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I don't think that all 730 memcals are the same; the knock signature is primarily a function of bore size (or so I've read) so you'd need a memcal from an engine with a similar bore size for proper knock detection.
Additionally the limp-home mode circuitry is likely to be different between different engine families.
A new '730 memcal from Dal (or gmpartsdirect) will set you back under $40.
--andrew
Old May 18, 2001 | 09:06 AM
89vette's Avatar
Anyone have a part number? Mike Davis lists one on his site that looks like part number 16151348. Can anyone verify this? Should I get one for a 90 Vette since I have a Vette?
Jason
89 Six Speed FX3 coupe
More Performance 396cid specs:
Callies 4340 crank 3.875 stroke
Lunati Pro-Mod 5.85" rods
SRP Pistons 14cc dish
Comp Cams Custom cam 550 lift 220/229 duration
10.8:1 compression
AFR 195 competition ported heads
Miniram and TPIS 1 3/4" headers
Old May 18, 2001 | 09:12 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If you're burning your own chips, probably doesn't matter F-body or Y-body. I doubt that limp mode will care, and the ESC circuitry should be the same for the same bore size.
You'll be changing what's "under the hood" anyways...
One thing I don't know of is if the 'vette has an oil temperature sensor (heard rumors of this) and if so, you might want to base your tuning off of a 'vette BIN file if the ecm uses this information...
--andrew
Old May 18, 2001 | 10:28 AM
leirch's Avatar
Assuming you have the oil temp switch(beings that its a vette). I would probly go with a vette memcal. I'm no expert, but i wouldn't *think* there would be too much difference.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 18, 2001 | 10:31 AM
89vette's Avatar
Wher ecan I find the part number for a 90vette memcal?
Jason
10.8:1 compression
Old May 18, 2001 | 12:47 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Call a dealer up. You could try asking for Dal at Vandevere Olds in OH.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
