Need suggestions on my idle problems.
Guys,
This is probly a toss up as to where this should go(either PROM or TPI). But my idle on my car seems to fluctuate between 825-950rpms and sometimes down to 700 if different temperatures exsist. The engines idle is fairly lopey. I don't know that i like it too much. Can somebody else that has the same cam or atleast comprable cam let me know how there car runs?
I'm trying to figure out if its a mechanicl/electrical problem or if its prom related. The rest of the rpm range seems to work ok.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
