ARAP bin - Some Q:s...
Old May 30, 2001 | 06:02 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
I have an '89 IROC with a 350 TPI, 700R4 in it, what changes do I need to make to the ARAP bin before I can try it out?
I've read something about the fan switches being inverted, can someone please help me straighten this out?
What would be a good starting point, I already have all prom burning equipment and a spare chip carrier for the ecm....
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Ed Wright Fastchip Stage II/160 stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 47 PSI
Old May 30, 2001 | 09:17 AM
ZaphodB's Avatar
Can someone at least give me a few hints to get me started on this?
Old May 30, 2001 | 09:55 AM
leirch's Avatar
What i would do personally would be to put a 180stat in, and then run the arap with the scanner hooked up so you can watch EVERYTHING thats going on.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 30, 2001 | 10:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
TunerCat's 6E.TDF now has the "Normal Operation Fan Switch" availble as part of its "Switches". Just select it and it will make the Fans work properly on the ARAP BIN.
Old May 30, 2001 | 12:24 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I thought that the fan switch was only a problem when running the 6E code in an '87 or '88. Since you have an '89, that should be a non-issue. I'd check it to be sure, though.
'87 IROC 5.7l TPI - original owner!
Old May 30, 2001 | 12:27 PM
P J Moran's Avatar
Engine: 5.7l TPI
Axle/Gears: 3:23?
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
TunerCat's 6E.TDF now has the "Normal Operation Fan Switch" availble as part of its "Switches". Just select it and it will make the Fans work properly on the ARAP BIN.</font>
"Normally Open", not "Normal Operation", FYI
[This message has been edited by P J Moran (edited May 30, 2001).]
Old May 30, 2001 | 12:28 PM
P J Moran's Avatar
Engine: 5.7l TPI
Axle/Gears: 3:23?
<font face="Verdana, Arial" size="2">Originally posted by P J Moran:
</font>
Disregard this. I hit reply instead of edit (by mistake)...
Old May 30, 2001 | 02:06 PM
ZaphodB's Avatar
</font>
So basically I could just burn the plain ARAP.bin image to start with (Since my IROC is an '89) and then have a look at the computer data with a scanner and see what I might need to modify?
Just trying to make sure I don't do any stupid mistakes.... But I guess will know abot the fan issue pretty quick if it's the wrong flag set....
About prom editors, which one is to prefer - I know of a least three different ones (Tunercat, Winbin and GMEpro)...?
Old May 30, 2001 | 11:05 PM
Like a ROC 89's Avatar
I have an 89 IROC 350 700R4 the same as yours. I'm running the ARAP bin and I had to change the fan tun on request to normally open for it to work. Just a thought!!!!!
Thanks again for the help............you know who!!
Old May 31, 2001 | 12:18 AM
ZaphodB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Like a ROC 89:
</font>
Thanks.... Which editor did you use?
Old May 31, 2001 | 01:22 AM
Tunercat
Old May 31, 2001 | 02:17 AM
ZaphodB's Avatar
Tunercat</font>
Do you know which byte contains the fan flag, because I'd like to try running the ARAP chip "as-is" before I try to narrow down what I need to do to it, and for the moment Winbin has all the options I need except for the fan-inversion flag....?
Old May 31, 2001 | 04:44 AM
Car: Death Mobile
Engine: 666 c.i.
The control for the "Normal Operation" of the fan is a "bit switch". You alter a single bit on a byte. I do not use Winbin so I cannot tell you how to handle this in Winbin.
As someone else mentioned, it affects ALL MAF cars, including 1989s. The car I installed it on was a 1989 and it had to this problem also.
Old May 31, 2001 | 06:25 AM
ZaphodB's Avatar
</font>
Is there any chance you could provide me with a copy of the original ARAP.bin with this flag set so that I can compare it and locate the byte that this bit is part of?
Old May 31, 2001 | 11:01 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The bit is also defined in the <A HREF="http://groups.yahoo.com/group/3rd-gen/files/89v4.ecu">89v4.ecu</A> file that's available from the yahoo third gen site.
You can use this file with winbin. A simple bit editor won't do the job for you as you also have to calculate a new checksum for the bin.
Here's the relevant ecu data:
/* Item 5: AC N/O - N/C pres switch */
/*startAddr =17,
/*columns =1,
/*rows =1,
/*elementSize =1,
/*bitMask =80,
/*offset =0,
/*mulOrDivOrBit =0,
/*factor =1,
/*map_name =A/C Pressure Switch Specification Byte,
/*ylabel =Option,
/*yaxis =b0 b1 b2 b3 b4 N/O P/S b7,
/*xlabel =Enabled,
/*xaxis = ,,
--andrew
[This message has been edited by afgun (edited May 31, 2001).]
Old Jun 1, 2001 | 03:13 AM
ZaphodB's Avatar
Thanks, now I think I've got everything straightened out.
Will get back with some reults after experimenting a bit..... That fan thing was a bit annoying
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
