flash proms
Old Jun 2, 2001 | 10:19 PM
fioremike's Avatar
flash proms
hi i am going to buy the pocket programmer to burn chips for a 91 l98 to program flash proms do i need a adapteris it more difficult to do ? thanks my prom id is 27c256 what is the flash prom to use for this 29sf256
Old Jun 3, 2001 | 08:50 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
We are using the AT29C256 Flash Prom. Its a direct replacement for the 27C256 and requires no special adapter.
There are PLENTY of posts on using the AT29C256, just do a search on "29C256" and you can read up on it.
The only "glitch" we seem to notice is that some computers need to have their "drivers" turned off in CONFIG.SYS or AUTOEXEC.BAT to make it program correctly.
Old Jun 3, 2001 | 11:25 AM
james_fearn's Avatar
Its not necessarily a glitch. If you read the instructions for the pocket programmer it clearly says edit you configuration files to remove types of programs. At least in my instructions that were on the floppy.
James
Old Jun 3, 2001 | 11:40 AM
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by james_fearn:
James
</font>
Yeah, reading the instructions is always a great place to start.
I personally had no problems with FILEPROM, except for needing Hex FFs pre-initialized. The Windows Version would not run on my older Toshiba computer, even after turning EVERYTHING off, altering the Parallel Port and allowing Win_prg to have the entire system to itself; it STILL won't program properly.
The Windows Version will run on my other notebook (Compaq 266mhz) with no problems, and found it tow work even with lot of other things running simultaneously. So it looks like the Windows Version has a minmum system size requirement.
Unfortunately, the ol' Toshiba is dedicated for my Prom Buring and other Automotive Software; so I'll just continue using FILEPROM.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
lewandom
Oct 1, 2015 08:15 AM
dusterbd
Sep 29, 2015 08:40 AM
