type of chip
Old Jun 10, 2001 | 05:43 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
type of chip
i know the best way is a customized prom but i dont wanna spend 400 just to spend more when i change the heads,so with that said has anyone ever swapped a t-5 inplace of the auto and if so what chip did you use?i have a t/a original 350 i swapped the t-5 in but know i cant use the 350 chip i have if i switch it over to the t-5 305 chip i have it runs like a dream the 350 gives it a really rough idle and surging problems along with a stall here and there coming to a light any reasons
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
Old Jun 10, 2001 | 08:40 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If you're using a PC, you can spend $150 on a pocket programmer (or be even cheaper and build one of the simple chip burners), then spend less than $50 and build an ALDL cable to use with Craig Moates' software and you can burn your own chips, tuned to your car!
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
bjpotter
Oct 4, 2015 07:48 PM
