N/A Logs Wanted
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
N/A Logs Wanted
I need some datalogs from some good running N/A 5.7's., avg comp ratio but not >11:1 with any cam or heads, I don't care. Would like to know if they are setup for milage, drivability or all out go power.
Weight of car if its real light or heavy, rear gear ratio etc will help with sifting the data.
Can be MAF or SD, DM or TP compatible just let me know the combo so I can view them correctly.
I'm trying to nail down some trending on spark tables and compensations.
Doing it just on my combo is not giving the results I'm looking for fast enough. I'm beating the crap out of mine to see where the MAP vs SA are during decells, cruise, wot at different temps/loads and I feel my motor will be gone before I reach a good conclusion. Hitting too many bad spots in my estimations, Transient conditions and temps are not helping me.
Haven't found anything on the net to help me with data so I figured if I see a wide variety, the trending may become clearer in general.
Shoot them via e-mail in my profile if you have anything you're willing to share.
TIA
TIA
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
