Hesitation issue. Must read!
Old Aug 17, 2006 | 10:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Since I've recently done this 727 ecm swap from a MAF originally, Car ran good, Though I had an aldl issue. Ended up being that I was running around in 'backup mode'. But the car ran just as strong as it did with my tuned maf setup. Now that I finally got a new ecm that fixed my backup mode issue, I started with a copy of super aujp v3. The car ran like crap. I get stumbles like when a fuel filter is clogged. So I tried just the stock hypertech chip I had, The car wouldnt even run for more then 5 seconds at a time. I modified the super aujp v3 bin for more fuel, less fuel, Ive ran stock timing tables. All runs the same, Like crap. Am I missing something here in the speed density tuning? I had my maf tuning down pretty good.
Old Aug 18, 2006 | 12:19 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Are you starting with the most basic things, like Cylinder displacement and Injector flow rate?
Old Aug 18, 2006 | 12:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Yes, I have corrected the super aujp v3 for my cylinder displacement, And fuel injector rate, As well as base timing of 17 degrees.
Old Aug 18, 2006 | 12:01 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Double check your fuel pressure to be sure the inj constant is figured right.
Adjust the o2 constants for idle a bit lower (like 50 mV) and the idle should improve.
Might need a new o2 sensor if you were running in limp mode. Could be all gobered up with soot and not helping things.
Are you rich or lean for the most part?
A couple around the block runs with DM and VEmaster will help get the bottom end running closer to 128's. Beats guessing when just roughing it in.
Old Aug 18, 2006 | 01:09 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
S_AUJP_v3 in a 727 ECM? I thought the 730 and 727 were pinned out differently? Not sure, never used a 727 ECM.
Old Aug 18, 2006 | 01:30 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
The harness connector pins are labelled different (4 connectors instead of 3) but the ECM's circuit board is essentially a 730 - except for the obvious connector difference.
Old Aug 25, 2006 | 10:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
which particular o2 constants should I adjust, I find four constants to play with and one table.
=Constants=
"Idle o2 rich/lean slow zero error lower"
"Idle o2 rich/lean slow zero error upper"
"Idle o2 rich/lean threshold fast"
"Idle o2 rich/lean threshold fast hysteresis"
=Table=
"o2 rich/lean upper zero reference error slow vs. map"
I am not quite sure which ones to adjust lower.
Old Aug 26, 2006 | 10:02 PM
JP86SS's Avatar
Sorry to leave you hang...
Take a look here for some direction on the changes and reaction to expect.
Go slow with the adjustments, they don't help things once you go too far.
https://www.thirdgen.org/forums/diy-...%2Fl+threshold
Old Aug 28, 2006 | 04:39 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
17* base timing? Do you mind if I ask why you're running that much base?
Old Aug 28, 2006 | 04:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Cuz thats how it idles best, And people on these boards suggested around that much because of the cam.
Old Aug 30, 2006 | 10:46 AM
Do you mean base, or idle? Base is what the distributor is set to, and should be adjusted for best cold and hot starting. Idle timing is the timing in the spark table, and should be adjusted a few degrees less than minimum MAP timing.
pjsparts
Oct 29, 2025 06:39 PM
Linson
Sep 21, 2015 01:08 PM
TrevinE
Sep 14, 2015 03:20 PM
webeeZ28
Sep 14, 2015 12:00 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
