How easy is it to make a prom?
Old Jun 15, 2001 | 12:05 PM
craiger's Avatar
I am thinking about getting the materials for burnnig my own proms. However, a friend tells me that it is really difficult to do, and you have to invest a lot of time in it and you risk a lot of problems burnning your own prom? I know of a friend who has his own shop and charges 300 bucks to burn a custom chip for your car. He finds out what mods you have and tunes you car on the dyno. If you add any mods, he will re-burn you chip for another 50 bucks. So what do you guys think i should do? Burn my own or have him do it on the dyno? Thanks for the info!!!!!
Old Jun 15, 2001 | 12:44 PM
Brent's Avatar
Burning a PROM is easy and takes approx 60seconds.
The testing of your car and learning what changes to make in the PROM to tune things properly is the time consuming part.
Get the stuff and start tuning!
[This message has been edited by Brent (edited June 15, 2001).]
Old Jun 15, 2001 | 02:11 PM
craiger's Avatar
My concern is that i can have a chip burnned for me for 300$ dialed in to perfection and a re-burn for
50$ if i add any mods. Burning my own chip would be cool for future mods', however, I am almost done with my mods. I plan to put a 383 in when it is time. So, its a matter of cost and time. So, how long does it take to have your car dialed in properly?
Old Jun 15, 2001 | 03:46 PM
leirch's Avatar
That all depends on how **** you want to be about getting it "dialed" in. If your worried about numbers, it will take forever if your concerned about good driveability then it won't take a LONG time but definatly months.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 15, 2001 | 06:57 PM
craiger's Avatar
Hmm?? So how much does it cost..software and hardware??
Old Jun 15, 2001 | 07:57 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Just a thought but it sounds like he's only going to be tuning the WOT settings. That's an easy and good way to tune WOT but how much time are you going to spend at WOT? Now, if he's going to tune the whole spectrum of driveability for $300, that's a deal as this could take quite some time. Of course it depends on the amout of mods (you didn't say) you've done to your car how much time this could take and he could change his price accordingly. Personally, I'd buy the equipment and spend the time. Plus, you could help/charge others once you have mastered the art. It will offset the cost of the equipment many times over.
Old Jun 15, 2001 | 08:01 PM
craiger's Avatar
Hmm? you make a good point. My mods: paxton sc running 8lbs of boost, tes headers, flowmaster 2x cat back system, crane hi 6s boost retard, 1.6 roller rockers, slp runners and ported intake/plentumn and portmatched. How much is it for the whole kit to burn the chips?
Old Jun 15, 2001 | 08:23 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Well, I have one more question: what ECM are you using? As far as a kit goes, there is none that I know of. You have to buy the individual components. One more question, have you read the prom burning intro at the top of this page. It has a LOT of info for newbies like us and LOTS of great links to sites that have very accurate and thorough info. Also, there are a few vendor sites for hardware and software. In short, you could buy the prom programmer and get a free editor and maybe some clean proms for maybe $250. Honestly speaking, if you are really new to this you need to take in some info first. You have to do a lot of research and listen to what the experienced guys have to say. Trust me, lurk long enough and the people who know will be easy to tell. I have about 6 years of working on carsd as a pro and I will be taking on my first EFI retrofit hopefully before the end of the year. I've been gathering info now for over 6 months and hope to be ready when the time comes.
Old Jun 15, 2001 | 11:04 PM
craiger's Avatar
I have the stock computer/chip. I have read some of the prom bruning intro althoug i am currently working full time as a paramedic and keeping up with my continuing ed PLUS going to school full time for my CCNA/MCSE. Ouch, no time! But always make time for the HOT ROD STUFF :
Steven 86IROC-Z
May 24, 2026 04:52 AM
Keith5
Aug 27, 2015 04:37 PM
BurlyChev
Aug 16, 2015 09:08 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
