Craig motes software
Old Jun 21, 2001 | 09:12 PM
87ColdAirIroc-Z's Avatar
Does this program have any thing for diagnostics? i would like to know before i spend all day downloading a program on this p.o.s. computer.
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old Jun 21, 2001 | 10:22 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
If your ECM coughs it up, my program will show it & log it. Diagnostic codes & such included. It doesn't perform any 'active' diagnostics, just data logging. You'll have to put your hinking cap on after the fact to figure out what's going on.
Old Jun 22, 2001 | 12:18 PM
Z28Man's Avatar
You won't spend all day downloading it, it's relatively small. It took me maybe 2 min to download over 56K. There is one program like 1M, took a litte longer for that but not bad.
Old Jun 22, 2001 | 01:05 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
SINCE I am a newby and I did a search for CRAIG, and really couldn't find the answer, I have a few questions.
1) What is Craigs software, from what I can tell it is like the DIACOM software, but a little more extensive for tuning purposes rahter than diagnostics only. AM I RIGHT?? Yes or No.
2) How much does it cost? & where do I get it,I was at his/your website, wasn't real sure what to download. Might not been on correct page.
3) Since I already have DIACOM, will the Parallel connector work with the program so I dont have to go buy another adapter? Yes/No.
87 Formula 5.1 converted to TPI Yellow/Black
SLP Dur 206/212, Lift 480/487, Cent Line 112 cam, SLP headers, SLP cat-back exhaust
K&N Airfilter
Modified Stock cold air intake
Ported & polished Stock TPI intake
Holley Adjustable Fuel Press regulator
AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connectors
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 22, 2001 | 06:00 PM
Car: 87 T/A
It's a lot like Diacom, just reads the datastream and stores it for future analysis. Also displays pages of stuff.
It's totally free and open-source.
I thought the file descriptions in terms of their necessity was made rather clear on my page, but perhaps I was mistaken somehow. The program is very small (about 0.1MB total for both needed segments), just download the thing and try it out. It has a 'testing' mode so you can look through what it does in the absence of hardware interface. It also has documentation, which will tell you what it does & how it works.
No, it will not work with the Diacom adapter. It will work with a serial port adapter (not parallel). The serial adapter can be home-made from $2 to $10 or bought for around $50.
http://members.tripod.com/moatesenhe...mecm/index.htm
Have fun, and don't complain, it's free.
[This message has been edited by Craig Moates (edited June 22, 2001).]
Old Jun 23, 2001 | 09:19 AM
okfoz's Avatar
Thanks, I will not complain... I promise,
Old Jun 23, 2001 | 08:51 PM
thanks guys i will try it
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
TC602
Oct 26, 2000 09:20 AM
