Running TPI on $0D
Old Aug 23, 2006 | 10:45 AM
blander66's Avatar
Running TPI on $0D
I am thinking about swaping out my 350 tranny in favor of a 4l60E. I have all the wiring and a computer from my s-10 that got crushed by a tree. I curentyl have speed density TPI and am looking to add the 4l60E using the PCM from the s-10. I would rather use only one computer rather than using two like i have seen done before with this conversion. Is it possible for $0D to run TPI?
Old Aug 23, 2006 | 10:49 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
HaulinAss- is the man to talk to on that. He has done it. At one point in time he offered to "fix" a "broken" ecm for an individual.
Old Aug 23, 2006 | 09:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yes, once the PCM is set up hardware wise, it will work. The PCM is ideally suited for that.
Old Aug 23, 2006 | 09:53 PM
blander66's Avatar
cool now that i know it will work what needs to be done as far as hardware changes and repinning the PCM connectors for TPI
Old Aug 24, 2006 | 09:05 AM
Car: 88 Camaro SC
Engine: SFI'd 350
You have to make some changes to the calpack (blue thing inside) to get the hardware set up for MPFI.
Old Aug 24, 2006 | 04:44 PM
blander66's Avatar
what mods need to be done to the calpack besides a custom chip?
Old Aug 24, 2006 | 06:51 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Can a 8625 ecm/harness be used for this?
I have one for sale that has been converted to run in a streetrod application if so. I opted for the 2001 PCM from Express van and pulled this one out.
Ron
Old Aug 25, 2006 | 10:22 AM
blander66's Avatar
scuzz i already have all the harness parts i need to make my harness but thanks for the offer
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
