87 prom on 89 TPI
Old Jun 26, 2001 | 12:02 AM
kryptotonics's Avatar
87 prom on 89 TPI
I am using a GM non vats chip(part #16068654) which I just found out is for a 87 could this cause performace problems also can this be why my car has idleing problems when cold?
Old Jun 26, 2001 | 03:16 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by kryptotonics:
I am using a GM non vats chip(part #16068654) which I just found out is for a 87 could this cause performace problems also can this be why my car has idleing problems when cold?</font>
Yes, it could - Because the pre '89 proms rely on the coldstart injector for extra fuel when the engine is cold. If you have an '89 TPI you should stick with an '89 prom.
Just get hold of an original '89 bin and disable VATS with Tunercat or Winbin, if you have a 350 /w auto you can have a copy of my original bin if you want.
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Steven 86IROC-Z
Today 12:59 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
