Building a Cable for Craig Motes software
Old Jun 26, 2001 | 05:04 PM
87ColdAirIroc-Z's Avatar
i have the diagram but am unsure or all the symbols and where to get the parts. I can find the capacitors, resistors, and cig-lighter adapter at radio shack. Where can i pick up an aldl connector, and a Max 232 chip? Also what does the other end of this look like the diagram does not show it?(serial port/parallel port)What pins do i use on the xxx port adapter? As for the wierd symbols they sort of look like a triangle made of dashed lines?
Also how many pins does a stock chip have (i need a zif socket)
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
[This message has been edited by 87ColdAirIroc-Z (edited June 26, 2001).]
Old Jun 28, 2001 | 05:51 PM
AlexJH's Avatar
Engine: 5.7L V8
1) I got the max233 from www.maxim-ic.com.
2) It's a 9 pin serial port. The connector that you buy from Radio Shack or whatever should be numbered. If not, have a look at the max233 diagram on Craig's site.
3) The triangle made of dashed lines is the symbol for electrical ground... is that what you were talking about?
4) ZIF socket is described in Traxion's article.
Now for the ALDL connector, I haven't figured that out yet...
[This message has been edited by AlexJH (edited June 28, 2001).]
Old Jun 28, 2001 | 09:58 PM
i have everythig figured out except where to get a zif socket and a aldl connector. I found a few zif sockets but there were several different sizes(# of pins)how many pins do i need. i could take it apart and look but if i do that i would like to install the socket.
thanks
jake
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
92firebirdguy
Sep 10, 2015 10:33 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
