Will this cable work
Old Jun 27, 2001 | 05:24 PM
87ColdAirIroc-Z's Avatar
This is the cable i am building for Craig Motes software,
http://members.tripod.com/moatesenhe...ecm/max232.jpg
will it work for my 87 iroc tpi or do i need the 10k resistor between the a and b aldl pins? also where can i purchase an aldl connector and a ZIF socket? radio shack doesn't have either.
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old Jun 28, 2001 | 12:07 AM
Mo's Avatar
Mo
From what I understand, you don't actually need a connector to plug into the aldl, just plug in the resistor and wire or connect them to something that is stiff enough not to fall out and plug that in.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Old Jun 28, 2001 | 01:09 AM
89GTA5spd's Avatar
I built the much simpler two transistor cable for mine. It only costs about $10 to build (if you spend $8 on the donor cable, but you can probably find one lying around). It takes only a few minutes to build and doesn't require the max232 or max233 ic. Search "cable" on this board and you will find a link to it. I have a MAF '89 car btw.
Old Jun 28, 2001 | 10:10 PM
I already have the chip and parts for the other cable so i am going to make that one. However i do need the 10k resistor between pin a and b right?
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
