would it help...
Old Jul 11, 2001 | 02:29 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
would it help...
Is it possible to make a stock L98 run faster just by playing with the PROM... Or will some mild to heavy mods have to be done first.
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Mods: SLP Exhaust, umm...nothing else..sorry
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Webpage coming soon.
Old Jul 11, 2001 | 06:35 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Ions91Z28:
</font>
There are too many variables to say if / or how much faster you could go. But, done right the engine would use less gas, and last longer. If you really *got into it* you could improve the drivibility of it.
Old Jul 11, 2001 | 09:51 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
For a stock L98 with only exhaust, you are doing pretty good already. Is it possible to improve it? Maybe...depends how close you already are.
I agree with Bruce that gas mileage can DEFINITELY be improved along with driveability. Also, it has been my experience that the typical L98 SD car is overly rich, so you may very well get some performance gain.
The biggest advantage is that you are at a perfect place to start to learn about eprom burning. You already have a fairly close eprom so you can ALWAYS return to what you originally had if you screw things up.
The worst thing to do is try to get into eprom burning when you swap out your engine to a big 406 Miniram with AFRs running high compression, big cam, etc etc etc. Then you haven't got a clue where to start. But starting with your setup will allow you to get into "tweaking" to see what works and what doesn't without having a good starting point.
I don't agree with the practice of these EPROM companies promising HP gains and time improvements. If the initial eprom is optimal, then you are already getting your max HP. I prefer to think that an eprom will allow you to attain the HP that your engine is really capable of attaining. If your intial eprom is way out, then you will experience performance gains. If your initial eprom is already close, then you won't experience much.
But you can STILL experience improvements in gas mileage and driveability even if your are already getting max performance. Max performance is a function of WOT, gas mileage and driveability uses many different parts of the programming.
Old Jul 11, 2001 | 12:50 PM
Ions91Z28's Avatar
alright, I'll look into trying this in the near future.
All I do is get a cable for a laptop and use craig moates software, connect it to my eprom... buy tunercat and go at it?
Is there anything I'm missing...? I keep noticing all these numbers as well.. like 70313 or something like that. What do those mean? which do I have. Sorry for the newbie questions, I've tried to use the search function as much as I could. Took me awhile to find craigs site.
91 Z28
Best Time Slip:
60' - 2.098
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
