long term experiment with gears for fuel mileage
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
I've been keeping notes on my fuel mileage for the past two summers. I've come to the conclusion that just because you add an overdrive gear, doesn't mean you will gain in the fuel mileage department.
I swapped from a 3.73 axle ratio to a 2.73 ratio for 1.5 summers. With my T5, this allowed me to drive the car as if I had either axle ratio (loose approximation).
3.73 * 0.75 (5th) = 2.7975
2.73 * 1.00 (4th) = 2.73
2.73 * 0.75 (5th) = 2.0475
The bottom line is I'm up about ~1 mpg with the 2.73s and 5th gear compared to 2.73s and 4th gear. My average mpg is up about 1 mpg between this summer compared to last summer (this is either due to my new engine loosening up a bit or my tuning experience getting better with time).
To gain any benefit from the extra gear, I think the engine needs a camshaft change to something closer to an LG4/L03 grind (which I'm not going to do).
Anyhow, just a curiosity is all. Anyone else experience this kind of thing? My average fuel consumption is 20-21mpg. I was hoping I could get it in the 25 range with the gear change, but I guess I need to look elsewhere.
Car: 1983 G20 Chevy
Transmission: 4L60
Good findings, I am back to my 3.08s and a stock 1,800 rpm converter with my 700r4 in my G20. I AM running the Peanut Roller cam in mine. Fuel mileage is up about 3 MPG and power in the normal driving ranges feels about the same as before when I was over-cammed and had 3.73s.
Engine: 5.7L TPI
If I still had the automatic, I'd probably keep the 2.73s and go for the peanut cam. With a manual trans, the long gear is getting old when driving in the city limits from a stop light.
How over cammed where you before? I'm running an Edelbrock Performer cam (2101?) at the moment.
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I experienced the same with the Monte L69 & 200-4R residing in my wagon..
I had to change out the 2.93 rearend, and the one that happened to replace it used 2.73 gears.. The car became a dog to drive and the motor was clearly unhappy about being lugged like that, and my MPG's dropped a lot. Soon I swapped the rearend for one with 3.23 gears, the engine was happier, I was happier, & my MPG's improved over the 2.93 gears (was up to 23mpg at one time, usually it's around 17).
Everything in a car needs to be tuned to suit the conditions where it spends most of it's operating time in order to get optimum performance (& MPG). So yes, not too high, and not too low.
