wanting to start burning but ?s
Old Jul 14, 2001 | 02:32 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
ok ChrisEtemadi and I are ready to start burning our own chips. we want to go halfs on the equipment and stuff since we live close to each other and can help each other out and stuff.
here are the questions
I have an 87 (mass air) and he has a 91 (speed density)
does the programmer work for both setups or do we have to buy a separate programmer for each setup since our chips are different?
what software would work best with both our setups?
anythin else we would need to know is greatly appreciated
thanks
Andrew
Old Jul 14, 2001 | 06:16 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
You can both use the same prom. A 256 can be used where a 128 is but not vice versa. Either way the proms are physically the same externally and a prom programmer can handle many types of proms anyhow.
Old Jul 14, 2001 | 09:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by smokin87iroc:
thanks
Andrew
</font>
Most all programmers will handle either of the proms your using. HOWEVER, you'll need two diffferent editors.
GMEPro, and Tunercat both make editors for both of those applications. GMEPro is DOS based and will run in cheapy laptops, and Tunercat needs a windows machine to run on.
I have both, and use them as outlined above
Old Jul 15, 2001 | 01:07 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Ok so If we get the TunerCat we will have to buy 2 different editors ? and everything else will work?
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jul 17, 2001 | 07:38 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Yup thats it, If you go with Tuner cat, you will only pay $20 bucks more. of course you will need more eeproms, I bought 5 for $35 bucks that included S&H.
I would HIGHLY recommend going with:
EEPROMS AT29C256 $5.++ ea + S&H
The Pocket programmer, $149.95 + ($6.00 S&H)
Tuner Cat (if your computer can handle it) $69.95
Tunercat's def files: ($6E or $32B) & $8D, $20 each
I recommend the AT29C256's because they are alot easier to program than the 27C256's. thats been what I have found...
I would HIGHLY recommend going with the $6E over the $32B, the REASON why is with the $6e you can get the '89 ARAP bin, I couldn't believe how nice it was even unmodified. Personally I bought both, just because I am that way.
John
[This message has been edited by okfoz (edited July 17, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Exxon Limited
Aug 9, 2015 08:13 PM
