problems with some programs connecting to ecm.
Old Sep 3, 2006 | 08:29 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Seems I can only get tunerpro to connect with my 727 ecm.
I would like to get Datamaster to connect so I can make some recordings and have VEtuner make me up a proper VE table.
any hints as to why I cannot connect? I used to make a connection with my stock 6e maf ecm.
Old Sep 4, 2006 | 12:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Tunerpro is set up to connect to any ECM as long as you have the right ECM file.
Datamaster has a separate program for each ECM, so your $6E version of Datamaster will only work with $6E ECM's. You need to download the $8D version of Datamaster to work with your 7727 ECM.
TTS Power Systems
Old Sep 4, 2006 | 04:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks! I'll go find out real soon if it works.
DiabolicalRS
Aug 26, 2015 07:35 AM
bdads
Aug 24, 2015 06:01 PM
djmarch
Aug 19, 2015 12:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
