the best program???
the best program???
OK I will eventually get around to burning my own chip. Now what I have instore for the motor is 1.6 rockers and the 2030 crane cam with the crane High rev kit(or something simalar)
What I have already is a 160 thermo and a polished intake runners. I have a 3.1 and I am looking for a little more pep for right now but want something that can still work well when the other things come into the motor.
Now I am not really "begging" for a prom just the best progeam to run with what I have and for whats coming.
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
Now I am not really "begging" for a prom just the best progeam to run with what I have and for whats coming.</font>
Since you mentioned you have the 3.1 engine, the choice of BIN editor will be fairly easy, you'll need Tunercat with the appropriate TDF file for your ECM.
If you have a look at the chip in the MEMCAL, what is the broadcast code written on it?
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Car: An Ol Buick
Engine: Vsick
The only right chip will be the one you modify to fit your application.
Car: Death Mobile
Engine: 666 c.i.
The problem with the 3.1 in an F-body is GM used the 404 instead of the 7730 ecm (like GM used in so many other 3.1 V6s. Further, there really hasn't been any 3.1 F-body owners that have gotten into prom burning, so information is really "skimpy" on the 404 and the 3.1 V6.
One possibility maybe to convert to the 7730 ecm and then you can look at using the $8D.TDF by choosing the proper "Cylinder Select". The $8D is thoroughly hacked and very well known. You could pickup a 7730 from a 3.1 V6 Cavalier and you could even look into using that Memcal as it would probably be the closest to your car.
I can't say how different the pinning for the 7730 would be from the 404, but I would suspect it would not be that great. When I get back from my business trip in two weeks, I can take a look at my 1991 GM Shop Manual and tell you the pinning differences between the two (7730 vs 404).
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
I can't say how different the pinning for the 7730 would be from the 404, but I would suspect it would not be that great. When I get back from my business trip in two weeks, I can take a look at my 1991 GM Shop Manual and tell you the pinning differences between the two (7730 vs 404).</font>
<font face="Verdana, Arial" size="2">Originally posted by ZaphodB:
Do you want to know which editor would be most suitable for you, or which BIN file you should start with?
</font>
</font>
Thanks for the help...
