165 86-89
Old Jul 23, 2001 | 09:20 PM
IROC-Z_85's Avatar
165 86-89
Is the 165 for all years, JUST a 165? were there any changes? Or the same dang box for all years??
thanks!
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
Old Jul 23, 2001 | 11:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by IROC-Z_85:
</font>
165 is short for 1227165, which is a gm part number. It was used in 86-89 FBody V8, amongst OTHER applications, ie some 4 cylinder trucks used them.
There have been some gm updates and supercesions.
Old Jul 26, 2001 | 09:36 AM
86Red4+3's Avatar
On another list, somebody once asked if the factory ever used reman ECM's (seriously!) and this response came from a GM mechanic:
<font face="Verdana, Arial" size="2">As for the reman 1227165 no car came from the factory with a reman ECM, but this is the original model ECM which was very prone to circuit board cracking and was a real problem so I would not be surprised to find a replacement in there. If you were going to replace it know you would use a 16198259 a much better ECM.</font>
So now I'm wondering if I buy a reman ECM from 'zone or carpartsdotcom and it's not specifically a Delco reman, will it still be the better ECM? I assume Delco by default uses the updated design when supplying a reman '165?
Old Jul 26, 2001 | 03:41 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would think it might be hard to say. I picked up a 16198259 in a salvage yard for only $20 because the guys book did not show the ECM part number, he was unsure what it was worth. I know locally I can get you a 1227165 out of a salvage yard for $58.xx out the door, if you have a trade in it was only $45.00.
S&H is extra of course. I guess what I am trying to say, if you need an ECM, try some salvage yards and go from there... Make sure they will stand behind the ECM, most places will only do a trade basis not refund your money.
For some reason this does not seem like a DYI PROM answer....
Old Jul 26, 2001 | 04:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 86Red4+3:
The problem is soldering, and traces lifting.
For the millions out there it really isn't a major problem. Just that it can happen. The only real cure seems to be just going MAP, with a 730. The Australian 808 which is the same board is trouble free.
One of lifes little mysteries.
69GTOby
Apr 18, 2016 02:34 PM
sreZ28
Oct 22, 2015 08:21 AM
ezobens
Aug 19, 2015 10:29 PM
james_fearn
Aftermarket Product Review
Jul 20, 2001 06:46 AM
BLOWN85/TA
Apr 23, 2001 04:42 PM
