Closed TPS Spark Advance Vs. RPM?
Old Jul 31, 2001 | 12:49 PM
leirch's Avatar
Guys,
I have been having a problem with cold start issues, the car runs well at 40d of timing or a little more/less at cruise. Well when I initially start the car it is a little ruff but not bad. But as soon as I put some load on it while driving it only reads about 20d of timing, give or take a few d. Is the above table the one used to adjust this problem?
I can actually watch diacom and after X amount of seconds it kicks out of "the routine" and bumps the D back up to 40+ and it runs great in open loop.
I've tried adding 10+ d to the startup spark advance with no ill effect.. Very odd.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 31, 2001 | 11:47 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Guys,
Brendan
</font>
there is a cold engine spark bias.
Rarely do you need to play with that.
Often the cold start stuff is too lean and that bumps the antistall code, and things look real confusing on a scanner.
I'd first try a little richer in cold start, and see if that doesn't help most
Old Aug 1, 2001 | 07:06 AM
leirch's Avatar
When I'm seeing the 20d of timing, I'm actually reading 900+ mv on the O2, it seems pretty rich to me.
Brendan
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
