Coolant sensor issue
Old Aug 2, 2001 | 07:06 PM
CWIROC's Avatar
I plug in Diagnostic and get a error of coolant sensor . i have replaced sensor and get same code. My temp gauge works fine and have cleared code and it comes right back. Could use some ideas.
1990 IROC TPI305, MSD 6A, DYNOMAX MUFFLER, MEGASHIFTER, 160 THERMOSTAT, HYPERTECH FAN SWITCH, AND A BLASTER COIL. WITH MORE TO COME!
2000 WS6
Dynomax muffler,
Paxton 12psi supercharger, Dynomax muffler and high flow cats, MSD ignition 6al and wires, corvette shift kit for my automatic tranny.
Old Aug 2, 2001 | 07:39 PM
HighHopes85's Avatar
The error code relates to the sensor going to the ECM. The sensor going to the dash is a different one. On most TPI's, the ECM Coolant temp sensor is on the front edge of the base and has 2 pins on it. Check that the wiring going to it is not frayed, etc etc. Also, check that you replaced the ECM senor and not the gage sensor. -Matt-
Old Aug 3, 2001 | 07:34 PM
CWIROC's Avatar
thats the sensor. *If unplug it gauge does not work. now you say there are to sensors. All i know is the one on the right side of the motor middle of block is coolant fan sensor and onthe left front side of block is temp sensor. So where is this second temp sensor or aka other sensor.
2000 WS6
Dynomax muffler,
Old Aug 3, 2001 | 07:48 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It's in the Base Manifold in the FRONT of the engine. Remove the serpentine belt and you cannot miss it.
It is NOT the one on the driver's side head (between cyls #1 & #3...that's the guage) and on the passenger side head.
PS: What does this have to do with PROM Burning? Your question would be better served on the Tech/General Board.
Bstrang6
Sep 8, 2015 04:29 PM
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
fonzie85
Aug 13, 2015 11:50 AM
