how to know when to adjust the spark map?
Old Sep 12, 2006 | 01:04 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I'm now trying to see how to know when its proper to make changes to the spark map, I have a datalog thanks to DataMaster I can watch, I am just not sure what to look for, and then how to know what kind of changes to make? Should I first look for where I see spark retard? Find that cell map vs rpm, and Remove that much timing accordingly, or what? And like always, thanks in advance for any tips or advice.
Old Sep 12, 2006 | 10:38 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Baby steps is the best way. Say your log has 3 degrees of retard a 3400-3550, I'd take 1 degree out from 3200 to 3600, and try again. Maybe next time It'll only show 1 degree, or less, retard at the same points. Knock begets knock, and encipient knock is the place to target.
Keep in mind that it's safer to be on the side of a little less knock, than a little more knock.
Old Sep 12, 2006 | 11:32 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
It also takes more retard to get rid of knock once you have it than the reduction of timing that started it. Try not to cure knock by flooding it with fuel as well. You'll just miss the tune altogether.
Its a back and forth thing that can try your patience if going too fast at it.
Once it is running good, try reducing the spark at a certain point and see if it makes a noticable difference or if it feels flat somewhere try adding a little.
Keep the tables reletively smooth so you don't induce surges from large transitions.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
Jlanz55
Sep 9, 2015 09:09 AM
