165 Knock Sensor on a 7730???
Old Aug 4, 2001 | 01:47 PM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
I have some info that a 165 Knock sensor can be used on a 7730.. the info I have states
<font face="Verdana, Arial" size="2"> Put a 4.3K resistor across GF9 and BB9. Then connect the knock sensor direct to BB8 (B7 on 165)</font>
looking at my notes.. GF9 is for the ESC which sounds right..
but BB9 in my notes is for the VSS low connection..
does this all make sense? Will this work or do I have something wrong
-=Jeff=-
89 Corvette Coupe White with Black Grand Sport Stripe
-=ICON Motorsports=-
Check out my mods on My '89 Vette
Old Aug 4, 2001 | 04:22 PM
mick's Avatar
I did not think that GM knock sensors really differ all that much between applications. I would also assume that a resistor such as that would actually disable the knock sensor, but I may be wrong.
[This message has been edited by mick (edited August 04, 2001).]
Old Aug 4, 2001 | 04:56 PM
leirch's Avatar
Those pin out directions seem kind of "half-assed". Why not just spend the 30bucks for the 730 knock sensor if you have any doubts. You can try the 165 sensor first. I ran a 730 knock sensor on my old 165 setup at first(I was switching back and forth without any problems until I got the 730 setup running well).
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Aug 4, 2001 | 05:05 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Brendan
</font>
I agree with that... I actually have the 7730 Knock sensor in the Block on the other side.. I need to call my GM parts guy and see if I can get the connector itself for the knock sensor and just wire it from the drivers side Like Mike Davis did.. this way I can swap back and forth as well.. If I do that.. My conversion will be 98% complete
Jeff
Old Aug 4, 2001 | 05:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by -=Jeff=-:
</font>
I'd just do it as GM designed it.
they do have reasons for what they do.
There can be a big difference from what will work to what will work correctly. Knock detection is not the place to make bad guesses. If you really sure of your work you don't have to run a K/S, but with the gas situation as it is, I wouldn't risk it.
Old Aug 4, 2001 | 05:29 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
</font>
Thanks Grumpy,
I think I will just get the connector and wire in the correct knock sensor, especially since I have it in the block
Old Aug 4, 2001 | 08:23 PM
89vette's Avatar
Supposedly its a proven connection. Mike Davis claims it works also but never posted it on the website yet. The VSS connection si just a ground. As you know I did this conversion and it didn't work. So I put in a 7730 knock senser. When I went to change the connections around, I realized that I never plugged the wire from the knock senser into the ECM. Duh! So I cannot say weather it works or not persoanlly. I would get knock counts on start up from the test routine. That's the purpose of the 4.3K resistor.
Jason
Old Aug 4, 2001 | 10:57 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
<font face="Verdana, Arial" size="2">Originally posted by 89vette:
Jason
</font>
Thanks Jason, I remember you saying it did not work for you.. but forgot that.. I think I might give it a try before running another wire
Old Aug 5, 2001 | 12:04 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The difference is in the ohms value one is...4300 ohms the other is 98000 ohms quite a diff.
Get the right one if you want it to work.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
